My N3735W Viewsonic LCD TV turns ON/OFF intermittently. No set pattern of time intervals. Turns OFF/ON between 1 to 4 minutes.
What I already tried:
1. Tried changing the power cable - No Success
2. Tried changing the power outlet - No Success
3. Tried to reset to default factory settings - No Success
Any tips please!!!
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: I need the code for
Try Phillips Remote Codes
10054 is the code for directv remotes. They seem to work.
SOURCE: Screen resolution - Viewsonic N3735w
Buy a monitor that wil accept your video card size resolutions?
SOURCE: Viewsonic N3000w LCD TV randomly shuts off...
hi,guys with shutting down viewsonic t.vs.
As you power up your t.v continously press input button on your tv
until it powers on.Sometimes last all evening,someyimes for 5 minutes.
your welcome
SOURCE: ViewSonic N2635w 26 in. LCD Television is not working
It can be bad main controller board. Check power supply first.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N2635w+
SOURCE: How do I reset a Viewsonic N2759w to Factory
On most Viewsonic TVs, hit menu (on the TV or your remote) go to Options (or Setup). The icon will look like a hammer with a double ended wrench across it (at least on my TV - a different model). Hit the down arrow and select Restore Default or Memory Recall. Select Yes and Enter when you see the prompt. Then exit the menu system (by hitting menu). The action is saved when you exit.
I hope this helps.
(the two different commands results from a change in Viewsonic's menu system - my print manual differs from the current on-line manual at Viewsonic's site. I'm not sure which set of commands will apply. If your TV menus are different, the names should still be similar.)
