Check for loose bolts: Over time, screws or bolts can become loose and cause the magnets to shift, leading to changes in resistance and affecting the bike's efficiency. Consider fastening bolts and screws in their respective places to prevent them from causing such shifting problems .
Inspect the console: If the electric console is malfunctioning, it can lead to error code issues that display on the monitor. Such problems need immediate repair before they cause the entire machine to stop functioning. You can either repair the existing console or replace it with a new one. It's best to leave this project to a specialist who can deal with it effectively .
Contact customer support: If none of these steps work, consider contacting HealthRider customer support for further assistance.
Run the software calibration for easy troubleshooting, and fix it. However adjust the REED switch, clean it, and tight all plug or connector very well. Please read you instr. manual or download from www.iconservice.com God bless you
ADJUST THE MAGNET, AND REPLACE IF NECESSARY YOU CAN TEST THE MAGNET AGAINT THE MAGNET DOOR FROM YOUR REFRIGERATOR, VS REPULSION +ATRACTION IF DO NOT PASS THE TEST REPLACE. READ YOUR INSTR. MANUAL OR DOWNLOAD FROM WWW. ICONSERVICE.COM GOD BLESS YOU
I had the same exact problem, and I mean the EXACT same problem. I also changed out the battery with no change. I contacted the generator company thinking it might be that, but they told me it could be the control board. I ordered a control board, changed it out, and now it works like new.
If the console has a battery, most likely it is worn out already. You need to replace the battery. Some rower consoles does not easily expose the battery. You have to open it with screw drivers.
Hey roger,
I have buyed me a E430 but i have problem with it.
does the bike work without the heart rate counter?
I don't have it and the resistance is always changing in every program.
So i like to know my bike is ok or not
