SOURCE: error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
SOURCE: Sharp AR-M280N
does this copier have a stapler on the finishrer?, if so there is a problem with the stapler, the finisher may need to be removed, but first check the lower exit tray and make sure that it is seated properly
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
