SOURCE: not recognizing new ink cartridge
We had the same problem and tried all steps Customer Service suggested each time; after several calls, it was determined we had a defective printhead... Kodak sent a new printhead, new ink cartridges w/ an envelope to return the ones I was using.
Apparently it's a common problem with this model; especially the earlier ones. Have had NO problems since the printhead was replaced.
I would suggest if you have recurring problems (even after Customer Service directives), call and ask if you might have a defective printhead.
SOURCE: need refill instructions for refilling the
From what I know, these cartridges have a chip that renders them useless if ran completely empty, (or if the printer registers them completely empty), and they will not work if refilled.
I think the only way to actually pull this off is to try to refill while the cart. is still printing,(not completly empty), and then it should work. This is a difficult one to refill.
SOURCE: Error code 1-2036 on Kodak ESP3 printer
Perhaps this will help, universal error codes for the Kodak 5100 thru ESP 9 inkjet printers:
RME: Kodak
STATUS_OK_ALL = 0,
STATUS_OK_MANUAL_DUPLEX_STARTED = 97,
STATUS_OK_MEDIA_DETECT_STARTED,
STATUS_OK_FORM_FEED_STARTED,
* Informational (0100-0999):
* Busy (1000-1999):
STATUS_BUSY_SYSTEM_BUSY = 1999,
* Warning (2000-2999):
STATUS_WARNING_IMAGE_TOO_LONG = 2998,
STATUS_WARNING_IMAGE_TOO_WIDE,
* Asynchronous Ok (3000-3099):
STATUS_OK_MANUAL_DUPLEX_COMPLETE = 3000,
STATUS_OK_PAGE_EJECTED,
* Asynchronous Warning (3100-3199):
STATUS_WARNING_BLACK_INK_LOW = 3101,
STATUS_WARNING_COLOR_INK_LOW = 3102,
STATUS_INK_TANK_INVALID_MANUFACTURER_COLOR = 3103,
STATUS_INK_TANK_INVALID_MANUFACTURER_BLACK = 3104,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_COLOR = 3105,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_BLACK = 3106,
STATUS_MEDIA_VERSION_EXCEEDS_FW_VERSION = 3107,
STATUS_INK_OVERFLOW_EXCEEDS_CAPACITY = 3108, // Will be deprecated
STATUS_WARNING_BLACK_AND_COLOR_INK_LOW = 3109,
STATUS_WARNING_PROOF_SHEET_WRONG_MEDIA_SIZE = 3110,
STATUS_WARNING_PROOF_SHEET_WRONG_SESSION_NUMBER = 3111,
STATUS_WARNING_PROOF_SHEET_NO_IMAGES_SELECTED = 3112,
STATUS_WARNING_PROOF_SHEET_READ_ERROR = 3113,
STATUS_WARNING_MORE_THAN_1000_IMAGES = 3114,
STATUS_WARNING_INVALID_DPOF_FILE = 3115,
STATUS_WARNING_NO_IMAGES_FOUND = 3116,
STATUS_WARNING_SCAN_TO_OPERATION_FAILED = 3117,
STATUS_WARNING_BLUETOOTH_CONNECTION_DROPPED = 3118,
STATUS_WARNING_UNSUPPORTED_USB_DEVICES = 3120,
STATUS_WARNING_OVERCURRENT_USB_DEVICE = 3121,
* Asynchronous and Synchronous Error (3200-3499):
* Job Recoverable. No User Interaction.
// STATUS_PRINTER_BUSY = 3201, // not used. duplicated number
STATUS_INK_TANK_REPLACEMENT_IN_PROGRESS = 3207,
STATUS_PRINTHEAD_UNCAPPED_TIMEOUT = 3208,
* Asynchronous and Synchronous Error (3500-3599):
* Job Recoverable. User Interaction Required
STATUS_ERROR_UNIT_OPENED_WHEN_IDLE = 3501,
STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY = 3502,
STATUS_ERROR_PHOTO_PAPER_TRAY_EMPTY = 3503,
STATUS_ERROR_PAPER_JAM_DURING_PICK = 3504,
STATUS_ERROR_NON_PLAIN_DETECTED_DUPLEX = 3505,
STATUS_ERROR_MEDIA_SIZE_MISMATCH = 3506,
STATUS_ERROR_INK_OUT_BLACK = 3507,
STATUS_ERROR_INK_OUT_COLOR = 3508,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_COLOR = 3509,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_BLACK = 3510,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_COLOR = 3511,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK = 3512,
STATUS_ERROR_PRINTHEAD_NOT_INSTALLED = 3513,
STATUS_ERROR_BACK_COVER_REMOVED_WHEN_IDLE = 3514,
STATUS_ERROR_CARRIER_STALL_DURING_PICK = 3515,
STATUS_ERROR_MEDIA_LOADED_UPSIDE_DOWN = 3516,
STATUS_ERROR_INK_OUT_BLACK_AND_COLOR = 3517,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK_AND_COLOR = 3518,
STATUS_ERROR_PHOTO_TRAY_ENGAGED = 3519,
STATUS_ERROR_FAIL_TO_DETECT_PAPER_EDGE = 3520,
STATUS_ERROR_VOLTAGE_TO_PRINTHEAD_NOT_CALIBRATED = 3521, // Should only be used at the factory
* Scanner (6000-6299):
SCANNER_ERROR_ADF_PAPER_OUT = 6101,
SCANNER_ERROR_ADF_PAPER_JAM = 6102,
SCANNER_ERROR_MOTOR_LOCK = 6201,
SCANNER_ERROR_MOTOR_MOVE_FAILED = 6202,
SCANNER_ERROR_HOME_NOT_DETECTED = 6203,
SCANNER_ERROR_CALIBRATE_FAILED = 6204,
SCANNER_ERROR_ADF_SENSOR_FAILURE = 6205,
/* Internal used errors. to be removed */
STATUS_ERROR_PAPER_JAM = 3201,
STATUS_ERROR_CARRIER_STALL = 3202,
SOURCE: Dead printer after replacing Cartridges in Kodak ESP3 AiO Printer
You should never use a COMPATIBLE ink cartridge or a ink cartrdge from different manufacturer......if you do then you are damaging your printer yourself and no one can help you not even kodak tech support.........try using genuine ink cartridge if you look on side of the ink cartridge then you will see a code which will indicate if its genuine or not try and match those codes with the codes that i will mention if it does not match then its not genuine...........
let me know if this was helpful.......
