Can copy but cannot print new document
SOURCE: Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
SOURCE: CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
SOURCE: Will not copy B & W document. Have put in new
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
SOURCE: Black ink won't print or
It looks like some of the jets are clogged. Try standing the underside of the cartridges in a shallow dish of hot water for a while, repeat several times if necessary and then try perform the cartridge cleaning procedure. If it does not work try taking it the shop to see if they can apply suction to clear them.
SOURCE: The black print won't print, but colour does,
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
