SOURCE: zone alarm code
check all the wire to that zone, magnets or movement sensor`s led is lit with every movement, it might be a damage wire or a mice bite hehehe, check the panel and make a bridge between the zone number and the common if the led zone turns off, u definitely have the check the wiring and magnets... becareful !! some magnets can give false contact... use a tester to measure continuity, other wise contact a troubleshooting for that brand....
SOURCE: I have a networx nx-12 (d.a.s.) home alarm and the
This indicates a low battery condition for the main control panel. Replace the battery in the main control. 12V 4-7AH usually.
Alarmprofessor.com
SOURCE: Can I adjust the volume on my GE Networx NX-148E
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
