Master
- Posted on Feb 26, 2013
Re: My HP Laserjet 4L has started jamming paper when I...
Here is some tips to avoid paper jam..
- If
your printer has a paper tray do not fill the tray to capacity. If
you're encountering frequent paper jams, reduce the amount of paper you
place in the tray each time it is filled.
- Make
sure you or the tray feeding the paper into the printer is aligned
properly and the slider used to hold the paper in place in the tray is
snug with the paper. Many printers have sliders that allow different
types and sizes of paper to be fed into the printer. If the slider is
not properly positioned it can cause paper jams.
- Use
standard office paper; folded paper, paper with labels, and specialty
paper such as hard bound paper can often cause paper jams. If you're
uncertain with what paper you should use with your printer your printer
documentation will list the paper compatible with your printer.
- Do
not mix the paper you're feeding into the printer at one time. If you
need to change the paper or size of paper being used removed any other
paper currently in the printer before inserting the new paper.
- If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
- Examine
the printer for any previous stuck paper in the printer. Previous paper
jams, torn paper, printing labels or other foreign objects in the
printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
