I have two batteries and charger (dc supply). When I rotate switch, I can only get playback to function. Unit will not power on when switch is in hdd record or SD card record. I am assuming its a dirty switch? or perhaps a fuse on the PCB. Thinking of pulling apart for a look inside to find fuse and also test selector switch. ANy infoon this issue or disasembly would be appreciated
SOURCE: Is there any way to record a video onto the sd card instead of tape?
You can't. SD card is only to take images in this camera.
SOURCE: Can you record video to the SD card on the Panasonic NV-GS25?
Yes very easy with a razor sharp knife you will need to cut it in middle.
When you did that you will have this [ ] [ ] if you put in the right part you will record video to sd card and the left side will put pictures on sd card , when ur done just put them together with some tape again and same thing next time
SOURCE: Unable to use Easy Editing function on HD Writer 2.0E for sx/sd
Did have the same problem. If you have copied (backuped) the files to your harddrive, you must have twice the amount of free space available (working-area) on your HD to be able to edit the videos with the panasonic software. Default the workarea is c:\ (choose settings in main menu --> HDD Settings --> Select working area) After changing it to the d-drive (80 gb available) i didn't get the message and could working again with the video's!
