You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
SOURCE: Hi. My Korg X5d shows a sequence of small squares
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
SOURCE: Hi, my korg X5D have
The pitch and modulation wheels are on a separate circuit board, if they both stopped working at the same time, it's likely the connecting cable has dislodged.
Opening an X5(D) is relatively simple and you should be able to simply plug the cable back in. If you're not comfortable doing that, take it to a shop.
SOURCE: how to turn on en
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Testimonial: "thank you 4 your insrtuction"
SOURCE: Hello my Korg X5D on switching on shows
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
