Question about Vizio P2 42 in. HD-Ready Plasma Television
VIZIO P42 plasma, half screen ok, other half showing blank
I have Plasma Tv. My screen is split. One half shows the picture, the other half shows one green band. What could be the problem. I opened the TV , but nothing looks short. I am knowledgable to certain extent on chnaging boards. Any help would be apprecated? Could it be mother board or the screen drivers. The screen is split vertically. So left side is blank and right side has picture.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 3 Answers
If you are familiar with using a DMM, the simplest way is to test each of the fuses mounted on each of the internal boards, which means that you will have to remove the back of the TV panel. Each fuse should not test open. If it does, you probably have a failed component/circuit on the board that the fuse is mounted on. UNPLUG THE TV BEFORE REMOVING THE BACK PANEL. Do not plug the TV in while you are testing the fuses. There are some seriously high voltages in the TV, plus there may be residual voltage from the large power electrolytic capacitors, so try not to touch anything and if you do, use just one hand with the other not touching anything.
Posted on Aug 19, 2009
    President:
  • Vizio Master
  • 1,779 Answers
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
6ya staff
SOURCE:
Vizio 50" Plasma VP50HDTV20A comes on with sound but screen shows rainbow colours before pictures comes and picture is blurry when on and not in full color. All the inputs have the same display.
If this is an old Plasma TV that you picked up somewhere, it may just be too old. Plasma screens degrade over time.
New plasma TV's are not common anymore, so I am assuming this one has been around for awile.
If it is new, take it back to where you bought it.
Apr 10, 2017 | Vizio Computers & Internet
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
Vizio p42hdtv10a
Bad interface circuit or power supply. Needs servicing..
Jun 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
yes you need to check the power supply board going to the pitcure tube board common problem bad transister
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
No video/picture
Solution is to get it fixed (hopefully under warranty).
I have the same issue after owning the Vizio 42" LCD for just 5 months. They are coming to replace the part this week. I will also be purchasing the extended warranty as well, to avoid this problem in the future.
Sep 01, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Jun 02, 2008 | Vizio L37 Television
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio plasma tv
what connection are uusont tivo ? have u tryed other sourses
Jan 28, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
1,376 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
