Right now I'm running it with a mac. Power Mac tower. Previously (same problems, its why I disconnected it) I was running it on a PC (windows 7).
SOURCE: my new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
Shutdown, Switch back monitors and try it now.
Good luck
Mike
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor
from power and from computer and test computer with different monitor
to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing
led on front of the monitor , and monitor turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or a broken contact, identified an internal fault and kicked in
, starting the flashing light.
If
you are in situation one, then the monitor will reset just unplugging
power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults
that can occurr are a blown capacitor on power board, faulty inverter
board, faulty input board, or a fault on LCD Digital Controller board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
SOURCE: after starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
