That TV is new enough to have a VESA standard connection on the back, try attaching the mount directly to the 4 screw holes on the back, tv's don't normally need an adapter if the back is fitted with VESA. if not you can find low cost adapter plates on www.etvmount.com for the most part any vesa adapter than matches your size will function fine.
good luck-
Will
www.compressionconnector.com
Mt TV does have a VESA standard connection on the back but the mount that came with the stand is too small for the VESA mount. That's why I need to use the universal bracket.
I'll check out the adapter plates...thanks~
