Canon mp 459 wish to save scanned document as word file
You cannot save a scanned document as a Word document.
You need to save it as a jpg image file first and the use a image to text/word conversion program to make a word document.
http://www.software112.com/search-program/1/convert+jpg+to+word.html
SOURCE: HP Photosmart C6280 Scanner
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart C6280
See page 80:
You will need the "All in One" software for your computer:
Software
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: I am using an HP
Well once you have digitized all the documents can they all be converted to PDF?
THen all you need to do is to make sure the titles are in numeric order as page 1 - whatever
Adobe PDF acrobat professional lets you place them all into one doc.
On the left open page options at the top of this menu you can insert after of befor all the rest of the docs just open the lead doc and then add pages to thea you will build a book
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
SOURCE: Can I scan documents into a PDF file with Canon MP
Scanned images can be saved as PDF, JPG, TIFF, or BMP files.
SOURCE: How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
1. Install the MP Navigator EX software located on the disc that came with the printer.
2. Go to Start > Programs > Canon Utilities > MP Navigator EX > MP Navigator EX.
3. Select Photos/Documents or Stack of Documents.
4. If Photos/Documents was selected, open the top of the scanner and place the document you wish to scan on the glass with the top facing to the left. If Stack of Documents was selected, flip the plastic tray open on the top of the printer and place the stack of papers in the tray.
5. Select the Document Type in the left pane, then click the Scan button.
6. The scanning process should start. When it's finished, select Save to save the document(s) as a JPEG, or select Save as PDF to save it in PDF format.
LLCOOLRYAN
