Home Logo
Anonymous Posted on Feb 27, 2013
How do you use loose tea to make tea in a pot?
Jimmie J Karr
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on Mar 23, 2015
Jimmie J Karr
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
31304
Points
282
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
Gladys Talbert
Level 2:
Habit-Forming:
  • Expert 130 Answers
  • Posted on May 12, 2015
Gladys Talbert
Expert
Level 2:
Habit-Forming:
Answers
130
Questions
0
Helped
73081
Points
481
The loose leaf tea gives amazing flavor, it is better in quality and taste than tea bags thus preferred by tea lovers. You can prepare a nice tea at home,
Put loose leaf tea in boiling water, add sugar and milk according to taste and quantity and enjoy.
John Carry
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 29, 2014
John Carry
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
5485
Points
A loose green tea is very simple and easy to made. you can use a basket to place in your mug or pot..
Anonymous
Level 1:
New Friend:
  • Contributor 49 Answers
  • Posted on Feb 27, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
49
Questions
29
Helped
19005
Points
68
If you want to make tea using loose tea, you can use an infuser which sits inside the pot and is made of netting. Infusers usually are a basket or have a lip which makes it easy to remove when you are ready. Tea buffs say that loose tea gives a much better flavor of tea than using tea bags.
2answers
Descale my tassimo
This is a great posting on how to descale your tassimo
http://shay.la/descaling-your-tassimo-on-the-cheap/
Feb 03, 2014 • Home
How long should tea brew in a teapot?
When you look in the pot and can see that the tea has brewed to your desired strength, you should take the bags out of the pot or they will keep brewing and make the tea too strong and bitter.
Feb 27, 2013 • Home
2answers
Where can I buy a glass tea pot and matching cups?
Glass teapots have become quite popular recently. Here is a link to the English Tea Store, where they sell a glass pot and matching cups.
http://www.yorkshiretea.co.uk/about-tea/yorkshire-tea-how-to-make-a-proper-brew.php
Feb 27, 2013 • Home
3answers
How do you make a proper cup of English tea using a teapot?
There's more to making the tea than just shoving a few bags in a tea pot and adding hot water. Lovers of English tea believe that you need to warm the pot beforehand and let the tea brew before you start. Take a look at this article on the Yorkshire Tea website that gives a good run down of how to make tea.
Feb 27, 2013 • Home
Will not make entire pot???
Look at all the lines and at the hole the hot water comes out ,there might be some blockage somewhere.Also try and put a mix of 6 oz of white vinegar and then 26oz of water and stop it after it starts for about 1 minute or two the let the mix sit in the machine. Hopefully there is scale built up on the heating coil and the mix of water and vinegar will most likely do the trick . Also look for blocked hole where the hot water comes ,Check the unit out for something blocking any holes. good luck.
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
1helpful
2answers
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
4answers
Can loose tea be used with this tea maker?
Loose tea can be brewed. I had researched more on the internet.
9helpful
2answers
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
