Kodak EasyShare Z710 Digital Camera Logo
Elizabeth Perryman Posted on Feb 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on my camera it says Meomory card unusable insert new memory card
Worked just fine then I took SD card out to delete everything off of then inserted again now it wont let me do anything if SD card is in also tried a brand new Sd card still says same thing
Anonymous
Level 3:
  • Kodak Master 32,281 Answers
  • Posted on Feb 28, 2013
Anonymous
Kodak Master
Level 3:
Answers
32281
Questions
Helped
7905764
Points
102259
Try formating the memory card using the camera's Menu - select format memory card.
5 Related Answers
Anonymous
  • Posted on Apr 17, 2009
SOURCE: Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
  • 102366 Answers
  • Posted on Jun 17, 2010
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Testimonial: "Exactly what i needed to know. Thanks!"
Anonymous
  • 19 Answers
  • Posted on Jun 30, 2010
SOURCE: Tried two different brand sd cards. c533 tries to
Try turning the camera off and then back on.Ensure that the memory card is the proper type for the camera. If the memory card is the proper type, try re- formatting the card using the Format option in the Delete sub-menu of the Playback Menu. If it will not format, it is probably corrupted. Replace the memory card
Anonymous
  • 747 Answers
  • Posted on Dec 24, 2010
SOURCE: Just purchased and installed SD
A bunch of stuff could be happening. First did you format the new card if not see if it can be formatted to the camera. if not then you will need to download the newest updates for that camera from the Kodak web site. For example the camera is set )internally) to accept a 1gig card and you installed a 2gig card it won't recognize the card until the camera firmware is updated. The easiest way is to format the card first.
blackbear94
  • 33 Answers
  • Posted on Apr 23, 2012
SOURCE: I just opened a brand
Kodak P850 is an older Kodak and supports only SD cards (NOT SDHC) up to 2 Gb (uses FAT filesystem)
I deleted all old photos on memory card. Took some new ones, but now they won't upload on my laptop. Was working fine before.
* Brand and model# needed for specific instructions.
* Check your warranty. Call for service.
*** Following is for information only.***
* Depending how you deleted the older files. If you just selected everything and deleted or reformated the card then the camera is looking for a specific formated card or folder to move the files to.
* It's also possible that without finding the correct file folder or format that the camera "Default" to the internal memory. You will need to re-insert the properlly formated (or use the format option on camera menu. I would suggest using another card.).
* Connect the camera to your computer to browse the pictures in the camera's memory. Download or transfer to your hard drive storage.
* Once you have archived all your pictures then insert a new data card and start over again following you camera's set up instructions.
Aloha, ukeboy57
Jul 06, 2018 • Cameras
My moultrie trail game camera d-40 will not store pictures on memory card. I have tried multiple memory cards. The card I have been using is not very old and has worked fine until now. Camera is showing...
Is the small switch on the side of the SD card pushed up toward contacts? Has the card been formatted by a PC(A NO-NO)?
Remove card;turn camera on..go to setup; press up arrow once to get "DELETE ALL IMAGES NO?";press select button to get flashing "NO"; press up or down button once to change flashing NO to flashing YES; press select once...should get "DONE";press select until back in "SETUP...Turn camera off insert SD card and try again...may need new SD card.
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
My lg viewty says i dont have a memory card when accessing camera
* i took my phone back to the o2 shop and they've given me a new viewty, it's fine now, obviously just a faulty phone!
1helpful
3answers
SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Memory SD full
Can you put the SD card in an external card reader and see any files? Did you format the sd cards in the camera? You should never format the cameras sd card with a pc.
2answers
Kodak Easyshare CX7430 losses memory when shut off
I have the same camera and the same problem. Can't use SD cards anymore, only the obsolete Multimedia Cards that are extremedly hard to find on shops because SD cards are the substitute for them... hope you can find a Multimedia Card. At least mine works fine with them.
Insert memory card, LCD turns lank
Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
1helpful
2answers
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
