Im trying to monitor vocals as well as the CD/tape in. But when I push the CD/tape to control I lose the vocals and when I push FX to control I lose CD/tape
Here is a link for the manual, can't download it but you can read it online.THESE words are written on page 9 of the manual," If you are recording a signal via the TAPE OUTPUT and wish to listen to this simultaneously via the CD/TAPE INPUT, do not use the CD/TAPE TO MIX switch. Doing this would create a feedback loop, since the signal would be routed, via the main mix, back to tape via the TAPE OUTPUT. To monitor the CD/TAPE INPUT, use the CD/TAPE TO CTRL switch to assign the tape signal to the monitor(s) or headphones. This will avoid the tape signal being routed to the TAPE OUTPUT."
It also says this under that,"If you want to monitor only the efects signal in your headphones or monitor speaker(s), press the FX TO CTRL switch. Now the signal of the efects processor can be monitored alone, and the main mix andnor CDntape signal is no longer present on the phone and control room outputs."
The link for manual is below
http://www.manualowl.com/swfviewer/viewer.php?ViewModeToolsVisible=true&FitWidthOnLoad=true&Scale=0.6&ZoomToolsVisible=true&ZoomTransition=easeOut&localeChain=en_US&FullScreenAsMaxWindow=true&SwfFile=%2Fmanualswf.php%3Fid%3D333864%26manual_type%3Dproduct%26d%3D2501bc0bd655f7f874a872da268a7ed6&ZoomTime=0.5&NavToolsVisible=true&ProgressiveLoading=true&ZoomInterval=0.1&CursorToolsVisible=true&FitPageOnLoad=false&SearchToolsVisible=true
SOURCE: How can I Play music from Windows Media Player on
you must use the ubuntu linux operating system or, windows7 to do this
