Asus transformer to connect with picopix 2055 projector which needs 2 USB ports and the Asus only has one although therei salso a mini HDMI output
You cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
SOURCE: I need a user manual for an Asus Transformer
The link for your transformer is here:
http://dlcdnet.asus.com/pub/ASUS/EeePAD/TF101/TF101_Full_0418d.pdf
SOURCE: how do i transfer photos from a usb stick to asus
You need to get the Asus Transformer Keyboard Dock. It has 2 USB port built in.
Buy it here on amazon.
Otherwise you need to a microSD card.
SOURCE: where do i find an asus operators manual?
You can download the manual in the language of your choice here.
SOURCE: I need a user manual for Asus Transformer EEE TF101
If you dont get through you can always try this onehttp://dlcdnet.asus.com/pub/ASUS/EeePAD/TF101G/e6640_TF101G_Manual.pdf
Testimonial: "the only issue for me at the moment is that I have accidentally placed 6 camera widgets on the page and cannot seem to delete them!"
SOURCE: Need Asus EEE Pad Transformer Manual in English
Here is a link to ASUS support for you pad. you will need to put in the OS, and then scroll down and you will see manual. In my case 43 were available. Eglish was the second one down. Follow the instruction on the page, it looks like you have to do this via your phone.
http://support.asus.com/download.aspx?SLanguage=en&p=20&m=Eee+Pad+Transformer+TF101&hashedid=gHh4q7I8dvWJzhdV
Hope this helps
