Cycles through wash mode then just does nothing , faint buzzing noise, very faint.
SOURCE: agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
SOURCE: Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
SOURCE: Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
SOURCE: washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
SOURCE: washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
