I don't know the make of the starter
My jeep does this sometimes with the remote start.Does your remote start fob have buttons on the sides?Also make sure all the doors are locking.It is most likely some thing to do with you replacing your battery since it started then.You can find the serial or model numbers on or inside the remote starter key fob.then do a search of those numbers on google bing or whatever search engine you like.
The remote box may be getting hot. need to have it tested
SOURCE: notstarting because sercurity system shutdown
You need to either replace the ignition lock cylinder or bypass the security system. If you need help with either one, repost.
SOURCE: Car won't start - anti-theft light flashing
it sounds like the immobilizer is faulty. this will shut off the electrical feed to the starter motor. you will need to take it to a garage to get this fixed.
hope this helps.
SOURCE: car wont stay started
Get the fuel pressure tested. Might need to change the fuel filter or (Worst case) the sending unit
SOURCE: My 2005 Saturn Ion won't start! I've had quite a
Body Control Motion device:
Common on thjis car call your dealer to see if they have a recall.
Good luck
Thanks Justin! What would be causing that, do you know?
Thank you Bill. After work I will check it out today. Someone had to jumpstart my car when the battery died also. Then I went right up and purchased a new car battery. And that is when the trouble started with the remote start. I wonder if something happened when they jump started it? I do lock the car when I get out of it everyday.
My remote starter does have 2 tiny buttons on the side of it.
when you are close to the car push the small buttons on the side one time each.When i said to make sure all doors are locked i mean to actually check them.My jeep was acting up and one of the doors was not locking all the way.You could not open it but it would not stay started till i fixed the problem inside the door.check them to insure you cant open any doors or hatches.then try it.you can make sure they are fully locked by pushing the lock by hand then try that.
O.K. Bill. I will definitely do that and let you know if that is what the problem is. Thank you so much for taking the time to help me with this. I really appreciate it.
