You must install the InnoTab 3S version of Learning Lodge. If it doesn't automatically install, you can install from setup files on the VTech website. Download the manual at http://www.manualslib.com/manual/551479/Vtech-Innotab-3s-The-Wi-Fi-Learning-Tablet.html
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
The dealer you purchased the grill from, should have the Owner's Manual, since he forgot to leave it with you. or you can contact the the manufacturer, the Robert H Peterson Company (800) 332-3973 and they can email you one as an attachment. The heat is adjusted by the burner knob(s) on the front of the grill, once the burner(s) is lighted. It operates very much like a gas range. You'll need the Owner's Manual to calibrate the sensor.
No where can I find anyone who has solved Uline Echelon ice maker harvesting issues. My Clr 2060 only now produces 1" solid slabs. In harvesting cycle, will not release individual cubes. Anyone fix this problem?
vlog
You need to drill out the rivets on the bottom of the drawer then slide the stainless sleeve up and out. Then you need to remove the 2 rivets on the middle part inside the gasket. Once you drill them out the insulation goes downward to remove. Then you will see the excess for the harness. Replace the rivets with flat head screws.
