Try rebooting the computer and as soon as it turns on tap on the "F8" key until a new boot menu appears, choose "safe mode" if the computer starts successfully in safe mode. restart it and allow to boot normally. If this fails comment back as to whether it started in safe mode or not and I will attempt to help you further,
SOURCE: Sony Vaio Laptop boots but no display except mouse pointer
do you reinstall window if not it look like a virus
SOURCE: Black screen mouse pointer visible after i enter my password
hi..this problem is due to the loading drivers
during the time of login.The reason for the problem
may be due to the following reason.some files could
have got corrupted while loading drivers that may be
some damage due to the windows file corruption or
due to the virus corruption.
try it out..
thank u..
SOURCE: Gateway m series right click nothing highlights at mouse pointer
how do i right click on my laptop?
SOURCE: my acer 6930 boot up but screen stays black with
Try this fix...
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
SOURCE: power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
