When I got my phone did'nt come with instructions so now I want to go into the internet and I can't, can you please help me!
When you hook up to the computer I created a folder called JAVA, and downloaded anything thats java into that folder...then using the phone I opened that folder and installed....it automatically links to the Java button in the first screen and you can use it. Took me a while to figure it out.
Do you know how to set it up so when I get calls or messages I see the name of the person and not the number? Thanks
[email protected]
Go to google .com and type in sci phone manual and then you just basiclly down load from there i hope this answered your problem
I68resources.blogspot.com/2009/01/how-to-install-java-apps-in-sciphone.html
this should help ya : )
You will need java games that run with the i68 touch screen. http://chinamanuals.com has some.
You have to save the numbers with +44 not a zero!
I have the same problem with my phone with the apps thing, for the phone numbers just put a 1 in front of every number (if you live in the USA) wherever you live just put the contry code infront and it will show up as the contact name not number.
I have the i683g also when you get calls save that number under who ever it is and you will see that name come up only thing is you have to delete the old number you saved
This is for UK users only. To get the caller ID on text messages and phone calls you must have two entries. Save to your phone book and sim card for each number. The one you save you your phone just have the normal mobile number ie 07712345678 then save that number on your phone. On your sim card replace the 0 with +44 and save it to your sim card. hey presto caller ID on text meassages and phone calls. hope this helps........................
Caller and Text ID on Sciphone. For UK users only, you need to save two entries for the same number. Save one number to your phone using normal mobile number ie 07123456789 then you have to save the same entry to your sim card but replace the 0 with +44. This will allow you to see caller and text ID bit of a pain but worth it so you can see who is calling...........hope this helps......
I got this i68+ sci phone and I went ti itunes and downloaded some free apps and now I cant figure out how to put them on the phone...I see them in documents but cant play them...what am I doing wrong?
cant download java games
