Acer Aspire 5500 5570-2609 Laptop Logo
Posted on Feb 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bootmgr it saying the mgr is missing
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 201 Answers
  • Posted on Feb 20, 2009
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
201
Questions
0
Helped
76010
Points
491
Try this:
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
OR :
try this
Boot from DVD -> setup recov. -> command prompt
<bootdrive>\windows\setup\scripts\bootinst.exe /nt60 all
should fix the bootmng
Boot mgr is missing on acer one running xp
You need to do a repair on Windows XP operating system.
Go to this WEB site and follow the instruction to do a REPAIR.
http://forums.techguy.org/windows-xp/507442-bootmgr-missing-error.html
1helpful
When i switch on my laptop it says boot mgr
The program that is supposed to launch the boot process of Windows (the boot manager) is corrupted. Follow this to fix it
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Advent roma 2000 laptop says BOOT MGR missing what do i do x
Hi here's how to resolved BOOTMGR error. I have also posted this troubleshooting procedure to one of my TIPS. Please click here.
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
System recovery not working.
hello try this website http://www.thinktechno.com/2008/02/09/how-to-fix-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
lets try this first and if it don't work we will try something else
just copy and paste in your address barr
hope this helps bob
1helpful
Hard drive compressed/bootmgr compressed
I'm assuming that you are running vista. Try one of the following:
You will require a Vista DVD to boot off of.
Proceed to the System Repair Option, and follow the steps. It should repair your boot sectors..
Or
Once you have booted up, Press SHIFT+F10 to run 'cmd' prompt.
Then at the command prompt type the following (hitting <enter>) after each line.:
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
