JustAnswerhttps://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ... 1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
https://www.askmefast.com > My_nordmende_tv_mo...
Normende tv red light wont come on Nordmende tv blue light flashing Nordmende ... said: nope. will turn on and work fine until the screen dims, goes black.
Contact the authorized service center for Samsung. It sounds that, you're not sound in repairing this TV. Do not proceed. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
hi there.you will need some capacitors replacing on the power supply board.they arent expensive at pennies each...yuor local repair shop may do the job if you take them the board along...
or easy to do yourself with a little knowledge of electronics and a reasonble soldering iron!!
regards,steve
Now,hook ur tv Air broscasting incommig tv signal.Give it power.Now,tv turn on have picture flashes few sec. than dies just have only sound left?Yes,than the long LCD inverter board is dead.The long LCD inverter board,help the LCD screen to get a baklight to get a picture.Tries websites like shopjimmy.com,Ebay,com to buy a refurbish LCD inverter board for the replacement.
There no lamp in the LCD tv only CCFO floorescent light tubes.U can't reset or adjust those CCFO floorescent light tubes.Those CCFO floorescent light tubes are design to work as a whole LCD screen for the tv that it.The tv power supply board is dead.That the board where the power a/c cord plug into it.That the power supply board,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.On the board u said u see flashing blue light,searches all around for those dead leakages capacitors,they alway bulges up on it tops or puff up on it tops.Replaced those dead capacitors or replaced the whole board.This actions will get the tv power stable again and work.
Power board is dead,U know how to solders?Take the tv aparts check the power board for bad Capacitors,like puff up or burst open,replaced these capacitors,should get ur power stable,come back.Or replaced the whole refurbish power board,buy at websites Shopjimmy.com,Ebay.com.
Hi Compgeek09 Please check CCFL is hooked in connector properly, all connectors of back light inverter board are plugged correctly, check also other connectors of removed boards while CCFL replaced. It doesn't seem issue of back light inverter board nor its related to ground wire of power plug to wall because tv was working before replacement of CCFL.
wont turn on red light just flashes? On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
