When I turned on my tv a few weeks ago the screen came up magenta. By turning off the set and turning it back on, the screen would correct itself. Now the magenta cannot be got rid of. Can you tell me what is going on? I cannot watch it.
I have the IDENTICAL problem. Here's what I did to fix it:
Push menu on remote, then turn the XD - on. That worked for me, but every few days it automatically comes off and I have to turn it back on again. Better than paying my tech $200 to replace main board. At least it's working for now. Good luck, hope this helped.
This is normally only caused by two things, 1st- if your using the RGB inputs make sure the green is securely connected or possibly a bad set of cables. 2nd- If your not using that set up then I would say you have a defective main board. Have it looked at by a servicer if you cant find anything wrong with RGB Comp input cables.
