Samsung LN-S4051D 40 in. LCD Television Logo
bob meffert Posted on Mar 02, 2013
Samsung 40" cycles on and off, has green screen and has high pitch noise
When you first cut it on has green screen and high pitched noise and then cycles on and off 3-4 times and then comes on ok. Can't seem to find this problem listed anywhere.
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Jan 29, 2008
SOURCE: High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Anonymous
  • 124 Answers
  • Posted on Nov 03, 2008
SOURCE: High pitch sound LN-T3253H
Hi There, Does this sound comes from the Antenna source? Can you use a DVD player connected to the television and see if the sound still exist. Thanks, Mike
Anonymous
  • 304 Answers
  • Posted on Jul 16, 2009
SOURCE: High pitch sound after Samsung HDTV warms up- very
The sound can be coming from the Y-Main bd, X-Main bd, or the Main Power Supply or a combination of those three bds. The Plasma Panel can also cause this. A trained samsung tech will have to trouble shoot the issue. I have found that by replacing the bds one at a time will eventualy eliminate the problem. However you must understand that all plasmas do emit a whining sound that is characteristic of all Plasmas and will not go away completely. If the Plasma is not properly mounted on the wall you can be hearing the amplification of the Normal sound because the sound is bouncing off of the wall.
roety
Eric Rotmil
  • 587 Answers
  • Posted on Aug 19, 2009
SOURCE: hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Anonymous
  • 16 Answers
  • Posted on Mar 20, 2010
SOURCE: high pitched whistling noise coming from tv after
you probably have a bad capacitor on one of the boards inside.
Testimonial: "Thanks. Is that an expensive fix?"
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
1helpful
2answers
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
2helpful
2answers
Samsung LNT3253H is making a high-pitched noise
I had the same issue. The tech that came out today removed the transformer on the power supply board, "resealed" it, and replaced it (re-soldered the same part back on) -- the transformer apparently vibrates because it was not properly sealed. BTW, mine was about the fifteenth that he has performed this repair on within the past couple of months -- all 32" and 26" Samsungs. Now, it appears to be absolutely silent.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
