Remote Control Codes For OLEVIA TVs and Instructions to program. Remote ... 3 - If your TV turned off then you entered the right code and setup is complete.
Nov. 13, 2019 - 5 Digits Universal Remote Codes For Olevia TV. 11144; 11610; 11331; 11858; 11240; 12272. Read down further to see the steps to program ...
Oct. 3, 2019 - For example, if you want the remote to control your TV or Blu-ray player, hit and release the TV button or Blu-ray button. The remote's On/off button ...
Look at the manual: try the 'brand code search' first; you'll need the code list that came with the remote control. If you don't have the list or this fails, try the auto code search or failing that, try manual code search (takes a very long time). See the link for the RCR6473R manual. http://www.rcaaudiovideo.com/docs/common/RCR6473R/RCR6473R_OM.pdf
The comcast remote will work just set it up to find the code automaticaly, you will have to push the channel button about 45 times be for it finds the right code but it will work.
BEVERLYQC:: How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
