I am using hp dv 6000 pavillon laptop i forgot the administrator password i cant login to the system please tell me easyest way or tell tell how to format if i format also i asking administrator password
my mail id is [email protected]
when you do a clean install just leave the password clearhave you tried to start in safe mode and login.
You can't post conmments that contain an email address.
I know a software can hack HP password windows 7,and I used it before,my friend recommended it to me,it is easy to use,and I do it by myself.It seems called Windows Password Recovery Tool 3.0.You can have a try!
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
when booting after the post (beep) press the F8 key and load in safe mode. from there try and login as Administrator, 99% of computers have no password for that login. if you have the welcome screen just click on it, if you have the network login type in "Administrator"
from there you can goto the control panel access the user accounts and change/remove the passwords (this is based on the idea your computer is running xp/vista...based on data from hp i'm going to guess XP is what your running)
Have your HP
laptop login password forgotten? Do you have another administrator? Have you created
Windows password reset disk on your HP computer when it is available? Or
whether you have installation CD?
If you have
administrator, just change HP login account to this administrator and access HP
computer with it. At this time, no matter which account, you can easily change
or remove its password on Control Panel.
If you have
password reset disk, on Windows login screen after you type incorrect password,
there will be a message "Reset Password" prompting you to reset forgotten
Windows password with reset disk. Just follow password reset wizard to do.
If you have
installation CD, it will help you to restore HP computer or repair computer.
But it is still dangerous for us to use it because it will delete some
important data on your computer.
In consideration
of data safe on computer, Windows Password
Genius provides a safe Windows password reset environment WinPE. With it
and in such password recovery environment, you will don't need to worry about data
lost or damaged.
If you have windows XP, boot the computer in safe mode. When you start the computer keep tapping the F8 key to the advanced boot menu. Select safe mode. It would give you the login screen. Select Administrator, do not enter any password, if you can get through, it means that you did not setup a password for the system administrator. Once you get to the safe mode window with the icons, you go to start, control panel, user accounts, select the user account that you used to login and delete the password. You can retype a password again and exit out of the window and restart the computer. You would be good to go.
If you have windows vista, and you have created the password reset disc, you can use that to reset the password. You need to boot the computer with that disc. if not, you need to run the system recovery on your computer.
i have also a problem like this. My password need to crack.
