How do I use the antenna matcher tuner on the pdc 5 3 function test meter?
You have to set it up by attaching the coax to the proper connector.Now check your SWR on channels 1/40/and 19 make sure you write down your results.Now if you can't get your antenna to read 2:1 then use the matcher to bring the SWR down. All you are doing is telling the radio that the antenna is a good match.
