I have successfully installed the BizHub on the Windows machine and have set each user for their authentication. I have gotten it installed on the Mac with the printer driver from the CD, but can find no place to put in the user authentication. When I use PageScope, it says User Authentication is not installed! How can I authenticate the Mac user. The MB is running Leopard 10.5.6.
SOURCE: How to enter authentication details for the Document Server ?
Hi there if you type in the internet explorer the ip address there you will have the machine information. Then login usually the login is
User name = Admin
Password = password or just enter leave blank
Once you are in there you will be able to change the details you need.
Cheers J
SOURCE: Cannot Scan To E-Mail
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
SOURCE: Konica Minolta Bizhub 250 Authentication issue
What you require can be achieved though the "public access" settings. This will allow you to control what can happen without requiring a log in.
