Many parts are obsolete, but some are. Looking at the unit though, the buttons under the LCD Display might just need cleaning. It does look easy though. To replace it, your would be looking at a new display module.
Did they? Need to know more. Is it just a latch or privy latch with turn nib? A spindle runs through the door latch cylinder into each knob so it could be a case of the knob has been knocked shifting the alignment out? Could be spindle too long and hitting inner ends of knobs or if knob has a spring, that has broken. Could be screws holding the knobs too tight. In most cases, its just alignment. Remove the knobs and dry assemble to see if the set works ok. You may have to plug the fixing holes with matchsticks, glued in, and after carefully aligning knobs in horizontal plane and through, re-drill a new hole with pilot drill and re-screw.
adjust the REED switch, see the diagram, clean itm , test for open or faulty, and tight the connector, 2) replace the old batteries by new ones, clean the contacts batteries very well. 3) tight the ribbon cables for keypads, and clean ti God bless you
Corrine, That knob is spring loaded. You need to pull it out...Hard. Before you do this ,support the walk board/deck frame. It will be free to fall down after hou pull the storage/locking pin out. You need to pull the pin out and hold it until the walk board clears the upright. Then be carfull and lower the walk board/deck/belt.
The fold up latch is on the underside of the walking surface. There is a chrome tube that has a pull knob on the side of it to release the treadmill and allow you to fold it down. You do need to lift the weight of the deck slightly to allow the pin to work freely. Once the pin is pulled you can ease the walking surface down flat.
Hope this helps.
There is allot of weight on the "Storage Latch". You may need to push forward on the treadmill a bit, pull the black knob, then slowly let the machine unfold. Taking the weight off the "Storage Latch" will make it easier to release the latch..
It is continuous. Some manufacturers used to say just "horsepower," when "continuous" horsepower was really a better measure. Consumers picked up on this and started asking your question. Now the horsepower quoted by almost all brands, including NordicTrack, os continuous. However, they got lots of consumers asking "What does 'continuous' mean? so now they just say "horsepower," even though it is "continuous" horsepower! For a full explanation of what this means, see treadmill answers.
