HP PSC 1210 All-In-One InkJet Printer Logo
A
Anonymous Posted on Mar 04, 2013
Hp m1218nfs printer setting language - HP PSC 1210 All-In-One InkJet Printer
rajeshtwtc
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 22, 2015
rajeshtwtc
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1426
Points
How to change language chinese to english
How to change display language from chinese to english on printer HP Laserjet P3015 printer
1) The display language can be changed by accessing the setting from the printer's control panel.
2) Go to the printer control panel and choose the settings, select date and language, and choose your preferred language and press ok.
3) After pressing it, the language changes automatically in the printer.
For more printer related support visit our website https://goo.gl/g8nmM7.
Hp laserjet printer m1218nfs
Here is the steps to change the language to english
I work for HP but my posts and replies are my own.
Click the Kudos star as a way to say "thank you" for helpful posts.
Be sure to come back and click the 'Accept as Solution' button on the post that solved your issue - it may help someone else .....
How to change the language settings from chinese to english in hp laserjet printer m1218nfs
>Select Wrench or setup button on the front panel
>Press the Right arrow button 4 times
>press ok to select language
>press ok once again to select english
Please follow the above steps carefully it is very simple i am sure you can do it.
2answers
How to change the language settings from chinese to english in hp printer m1218nfs
Press Menu button..one time
Press " >" arrow button seven times,
Press enter,
Again press enter.
Go to English language with help of arrow buttons, to save the language press enter..
How do i change the language on my hp MX308
HI,
Follow these steps to reset the language and region on the product.
  1. On the product control panel, touch Setup. The Setup menu displays.
  2. Preferences . The Preferences menu displays.
  3. From the Preferences menu, touch Set Country/Region . The Set Country/Region menu displays.
  4. From the Set Country/Region menu, touch and then slide your finger up or down on the display to scroll through the list of countries, and then touch the desired country/region. The Preferences menu displays again.
  5. From the Preferences menu, touch Set Language . The Set Language menu displays.
  6. From the Set Language menu, touch and then slide your finger up or down on the display to scroll through the list of languages, and then touch the desired language. The home screen displays in the new language.
Thanks,
HP Printer Support
2answers
Hp laserjet 2840 - need to reset language to english from a foreign language I do not understand
Under device settings Go to system settings, Then go to system setup. You can change the language from there.
k24674
Grand Canyon Tech
Grand Canyon Tech
