SOURCE: kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
SOURCE: KitchenAid Superba 48 Refrig
hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
SOURCE: my kitchen aid Superba 48 the meat drawer is
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSCS25INBL01&productCategoryId=0165000&brandId=0593&modelName=COUNTER-DEPTH-REFRIGERATOR&diagramPageId=00003&componentDescription=REFRIGERATOR%20SHELF%20PARTS&documentId=W0606038&blt=06
Eric
SOURCE: change water filter kitchenaid superba 48
The Kitchenaide is very much the same see if this is helpful. Sea Breeze
IF not then contact me, Thanks, Sea Breeze
SEA BREEZE APPLIANCE PARTS AND TECHNICAL SERVICES
SOURCE: I have a KitchenAid Superba 48 inch side by side
The motor that pumps the water to the door is probably shot. The ice uses a seperate pump motor this is likely the reason the ice works.
