SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
