Brand new lifelite leaf blower ran for 20 seconds, shut itself down and hasn't started sense !!! lost receipt and $160!!!
Cause 1Spark Arrestor
The spark arrestor is a small screen that prevents the engine from emitting sparks. Over time, the spark arrestor can become clogged with soot. If the spark arrestor is clogged, the engine may stall. To unclog the spark arrestor, remove it and clean it with a wire brush. You may also replace the spark arrestor.
Cause 2Carburetor
The carburetor might be clogged. A clogged carburetor is most commonly caused by leaving fuel in the leaf blower for a long period of time. Over time, some of the ingredients in the fuel may evaporate, leaving behind a thicker, stickier substance. This sticky fuel can clog up the carburetor and cause the engine to stall. If the carburetor is clogged, try cleaning it with carburetor cleaner. If cleaning the carburetor isn't effective, rebuild or replace the entire carburetor.
Cause 3Carburetor Repair Kit
Cause 4Fuel Filter
The fuel filter might be clogged. A clogged fuel filter is most commonly caused by leaving old fuel in the leaf blower. Over time, some of the ingredients in the fuel may evaporate, leaving behind a thicker, stickier substance. This sticky fuel can clog the fuel filter and cause the engine to stall. If old fuel was left in the leaf blower, drain the old fuel from the fuel tank and replace the fuel filter.
Cause 5Air Filter
The air filter may be clogged or dirty. If the air filter is clogged, the engine will get too much fuel and not enough air. As a result, the engine may stall. If the air filter is clogged, replace it.
