Question about Sony DAV-S300 System
Surround sound to work with sky+
Is it possible to watch sky tv using the surround sound on my Sony DAV S300?
Will an optical cable work between the dvd player and Sky+ box to enable this sound function?
  • mattbarton75 Feb 20, 2009
    Am I best connecting the two with a optical cable? To be honest I'm not even sure if the DVD player supports an optical cable.
Hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Posted on Mar 26, 2009
  • 10,594 Answers
I think it should work if sky+ transmit surround sound signal.
Posted on Feb 20, 2009
  • Shahid Electronics
    Shahid Electronics Feb 20, 2009
    If it has optical input then it will give surround sound. you can connect normal RCA red-white audio cable in dvd player input to get surround sound in Amp Menu options.
6ya staff
SOURCE:
Hi, I have bought a Sony Dav s550 Surround Sound System. When I tried to set it up all I got was a picture on the tv but no sound. I checked the fibre optic lead even bought a new one but still no sound...
Check to see if your sky box has an output for fiber optic cable, if it does then go to the box configuration and make sure its enabled. Also is possible to transfer sound through HDMI so if your sky box has an output make sure audio is enabled.
If the box does not have the fiber optic out or HDMI then you will have to go old style with regular red and white audio cables and connect them to your home theater system. If you want audio for both TV and surround system you can use Adaptor Splitter 1 Male to 2 Female Audio AV
and get two of them, one for the reds and one for the whites that will be connected to your sky box, i hope it all makes sense and helps.
Jan 09, 2013 | Audio Players & Recorders
How do get sound surround interface between my HD SET TOP BOX and my Sony DAV-S300. I have seen previous responses and digrams with connection to the Optical in socket on my DAV but my system doesn't have...
http://hd.sky.com/hd-television-equipment/hd-set-top-box/
http://hd.sky.com/hd-television-equipment/input-output-connections/
http://www.ehow.com/how_5890852_convert-hdmi-rca.html
The first two links you've probalbly seen before, they show conncections and connectors. I looked at pictures of your system and it would appear that the only input for video and audio is RCA. I think it has s-video for video only(s-video slightly better). The third link is the only way I can see to get what you are asking. It is an HDMI to RCA adaptor. You would use an HDMI cable out from your set top box to the adaptor then, RCA cables to your DAV-S300. It's the only way I can see. Hope this helps.
Mar 11, 2011 | Sony DAV-S300 System
I have a sony dav-s300 , a Sharp Aquos tv, a sky box and a ps3. I can get them all to work but not in surround sound. Can you please advis how i can watch the dvd and the ps3 in surround sound.Is there a...
A stereo 2 phono lead input from a sky box will have dolby pro logic surround info on it (when its a surround programme of course)
The Sony should then process this and give sound on the centre and rears too.
The DAVS300 does'nt have an optic/coax digital input so you can't have dolby digital from an external source- only from its own DVD player
Sep 04, 2010 | Sony DAV-S300 System
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Oct 15, 2008 | Sony DAV-S500 System
Sony dav s300
what cable uusing u hav eto tell ps3 480 i or p not 720 or higher unless uusee hdmi cables to hd tv then digital out back to sterio
Jan 09, 2008 | Sony DAV-S300 System
Sony DAV-S300 System Logo
687 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
