Are you using an auto-focus m4/3 lens? I have about 20 lenses for this camera and only 1 of them is an auto-focus m4/3 lens. I have an adapter so I can use my 4/3 lenses on it in auto-focus mode along with other various mounts (including cctv) that do not support auto-focus. So if you are using a non-auto-focus lens, you will need to manually focus the pictures.
If you are certain it is an auto-focus lens, are you sure you have it set to auto-focus?
What settings do you have your camera set to (aperature mostly is what I'd like to know)? Try adjusting your aperature to be small (to increase your DOF).
Also what lens are you using and what is your focal distance? It could be your lens has a larger or shallower focal distance than what you are trying to achieve (like a macro lens doesn't work that great for landscape photography or a telephoto lens doesn't work great for macro photography).
Last thought: is your lens or sensor dirty? A dirty lens can cause focusing issues if it is REALLY dirty and a dirty sensor can too (sensor is a bigger pain to clean. I strongly recommend taking it to the pros as they scratch really easily). Dirty lenses can be cleaned with a blower and a lint free cloth and rubbing alcohol if those 2 things don't clear it out.
SOURCE: MY OLYMPUS DIGITAL CAMERA FE-230 IS OUT OF FOCUS?
Try one of these tips:
>Hold your camera steady using both hands
>Hold your breath just before you take a hand-held shot
>Use a tripod, or a set your camera on a steady surface
>Set your camera's self-timer
Set the dial mode to auto ;
Turn off macro mode;
Turn on the camera's flash.
At the link below you will be able to download the instruction manual for Olympus FE-230 Digital Camera:
Click HERE
SOURCE: i have digital camera olympus FE series. The
yes can be repaired,it is the problem of the focusing unit of the lens unit.
