Hello cjsmith12345 - Are you certain the error code is C8? However, if you are receiving an error code E08 it typically indicates a shorted keypad, or a faulty User Interface Board. Depending on the model, these components may be the same. To reset, turn the power off to the unit for two minutes. This may be done by either unplugging it or flipping the household circuit breaker off and then restart unit. If error reoccurs, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Thank you for your inquiry, Carol!
From what you have described your Electrolux range is displaying an error code of E15. I see you have reset your breaker and continue to receive the error code. The error code E15 means that your ESEC (Electronic Surface Element Control) test failed this could be a problem with your relay board or UIB (User Interface Board). When you reset your breaker did you leave it off for at least ten minutes? That is the best way to reset your range. You may need to seek assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Good Afternoon Paolo, thanks for your post!
I see that you need to reset your Electrolux dishwasher due to replacing relay and an error code. The best way to reset your dishwasher is to disconnect power from it for roughly ten minutes. I hope that this information is helpful to you. -Matt
I appreciate your post, friend!
Based off what you are describing your Electrolux cooktop is flashing error code "8". Normally, an "8" error code stands for key sensor for cook place 3. This means you could have a problem with your center board or left board. I would recommend performing a reset on your cooktop which can be done by flipping off the household circuit breaker for ten minutes. If the issue remains I would consult with a professional technician for diagnosis and repair on the cooktop. I hope this helps to some degree. -Matt
