How do I reset the function keys on an MC9090?
Sound like you need to look at your Keyboard mapping files, easiest way to fix this is to use Motorola System Configuration Manager - Downloadable from the Motorola website.
If the unit need to be restored to factory defaults, than a fast way is to run the Clean boot files from the SD Card also downloadable via the Motorola site - search for 'MC9090 Clean boot'
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
