This TV Sylvania have all voltage of power supply ok , but no power on, only blink led green in front the tv.
SOURCE: Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
SOURCE: have URC-4330B03 want to program 13in sylvania TV
here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
SOURCE: need code for SRC2213X with Radio Shack Remote (Sylvania TV)
I was having trouble finding a code that worked for my new RCA Digital TV converter box, model DTA800B1, remote for use with the Sylvania SRC2213X Color TV/VCR Combo. I found another site that had a guy saying he stepped through and found code 116 worked. I tried this and it worked for me too! If you are using a 4 digit code, probably 0116.
Here is where I found my help (if you want to see the original post): http://tv.manualsonline.com/ex/thread/view/idThread/777397
