New Home HF-504D Mechanical Sewing Machine Logo
Posted on Oct 07, 2017
I have a New Home HF 504D, bought maybe 7 years ago, not used a lot, but moved several times. It seems like something is out of alignment. The wheel does not turn all the way without running into something. The weird thing is when I re-thread it, it will sew fine for one time, but when I let up on the pedal and try to start sewing again, it is jammed.
1 Related Answer
Anonymous
  • 323 Answers
  • Posted on Aug 27, 2008
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
How to thread New Home HF-504D ?
https://archive.org/details/NewHome539SewingMachineOwnersManual
www.ismacs.net/free-sewing-machine-manuals-list.html
Need owner manual.
have to contact janome customer service or a janome dealer about a manual
Sewing machine jammed while sewing
go on line, google for- new home hf-2022 sewing machine and down load pdf manual for machine
Replacement parts
try
sewingpartsonline.com
premiersewing.com
sewusa.com
Do you need a rolled hem plate to make a rolled hem?
No, you could pin the hem in position as desired and then carefully stitch it, removing the pins as you go along.
I need to learn how to thread it! please help. i have a New Home HF504D serger. it came with a tape to give instructions, but they are not very clear! HELP!
You need to be shown, its impossibe to describe in words. Either someone you know with an overlocker, a machine dealer or sewing classes.
I was given the machine with no manual. I can't figure out how to wind the bobbin.
Call Janome at 1-800-631-0183 and see if they will send you a manual or let you purchase one.
3helpful
I need the manual for New Home HF504D machine
You can get a new one from a New Home or Janome Sewing Machine dealer.
Top New Home Sewing Machines Experts
NOEL
NOEL
Paul Bade
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
