Question about Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer
Front load washer mold smell
How can i get rid of the smell ?
    President:
  • 2,976 Answers
Run an empty load of Clorox water. Put double in and run the complete wash & rinse cycle. It will kill the mold spores. Keep the lid open when you're not using it.
Posted on Feb 21, 2009
6ya staff
SOURCE:
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
What can ido to get rid of musty smell
Here is a tip that I wrote about that...
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
May 19, 2010 | Hotpoint WMA40 Front Load Washer
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you get rid of the moldy smell in my front load LG WASHER?
There are some products out there that you can purchase from any Walmart or Grocery chain but what works real well is a mixture of concentrated lemon juice and water. You can make a permanent solution for this use by taking a spray bottle and filling wih 2/3 water and the rest lemon juice, (concentrated), and praying this around the boot and then wiping dry.
Jan 31, 2010 | LG WM-2277HW Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold and smell
This is a problem common to many front load washers. Besides being very important to wile the the rubber boot down thoroughly there are a couple of products that claim to get rid of the mold and smell. I, myself, have ***** tried these but you might want to give it a shot. One of them is called Purewasher and is offered on the site www.smellywasher.com. Some time ago Maytag came out with a Mildew/Odor kit that they may still provede. again, I don't know for sure how well it works but it too may be worth trying
Jan 27, 2008 | Maytag Neptune MAH9700 Front Load Washer
Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer Logo
94 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
