SOURCE: All the copies are coming out solid black
On my copier the exposure would light when I made copies but come to find out it wasn't bright enough. Look at the lamp and see if it doesn't have black burnt spots. If so then it is the lamp.
Good luck
SOURCE: "waste toner is full"
pull out your drum unit. locate green tab on the right top of unit. now, take out one screw and remove small cover on the rear, right side and empty very carefully.
hth,
razors
SOURCE: ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
SOURCE: i need location of a waste toner in a copystar cs
i don't think it has one...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
