There are several things that will allow that to happen. Could be both injectors are bad (not very common). If the fuel regulator is leaking the gas can be draining into the intake ports of these cyls. The regulator in under the intake manifold and you will have to take off the throttle body to look at it. With the throttle body off, turn the key to the on position and see if it is leaking.
