Televison & Video Logo
Posted on Mar 06, 2013
HORIZONTAL LINES AND NO VIDEO
THE SCREEN REMAINS BLUE AND WHEN THE CHANNEL OR ANY COMMAND IS GIVEN,DISTORTION OR HORIZONTAL LINES APEAR.
2helpful
Horizontal AND vertical lines on TV screen
Most likely the main board...try locating one on Ebay, then go to you tube for a "how to replace" video.
1helpful
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Just replaced my vizio 4kUHD LED main digital board, but am still having horizontal lines causing screen distortion.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Plz help me... after i reformat my emachine laptop from a command promt.. when i restart it it says BOOTMGR MISSING.. when i reinsatll the OS a blue screen apears... and it says.. "a problem has been...
You will need to reformat the computer again. You may want to try pressing F11 when you first turn on your laptop and recover it from there.
If the issue remains after this and you are getting blue screens this could mean that there might be a hardware issue and you will need to contact your laptop's support line as it might need to be fixed.
1helpful
I have a Samsung MX20 Camcorder, when I turn the it on the LCD shows a distorted image with horizontal lines no clear image or anywhere near. Any help appreciated this was given over a year ago never used...
The horzontal lines would have to do with the screen unless you see those on the actual video footage on the memory stick.
Fact is I have this cam and know everything about it by experience the issues with these cameras one drop and there basically toast.
Now if there is not horizontal lines on the video itself and the video is clear the issue would be the LCD on the unit.
Let me know and update me with any new information.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have a sharp tv 21" if i turn it on or change channel,pink display will appear with red horizontal lines about half inch intervals dn a few seconds it will turn normal but the red horizontal lines remain...
my sharp tv was like that to but our tv color was blue with also gray horizontal lines i did cheack all d caps resis... etc dont know what to do LoL.
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
Top Maxent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
