Televison & Video Logo
Posted on Mar 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
It started with about 4 small white dots on the screen now it has hundreds of white dots. it is getting worse and now it is getting harder to see the picture. i have check the back of the screen it is not on the screen.
Jerry Radcliffe
Level 3:
Master:
  • Master 483 Answers
  • Posted on Mar 07, 2013
Jerry Radcliffe
Master
Level 3:
Master:
Answers
483
Questions
0
Helped
92585
Points
1325
Projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
5 Related Answers
Anonymous
  • Posted on Apr 25, 2012
SOURCE: White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
robert landry
  • 96 Answers
  • Posted on Mar 15, 2008
SOURCE: Pink Dot in center of screen.
Well, You have a bad engine, so what other's called lcd projector motor.
This will cost you, the engine states at about $500. I've seen this problem and right after I've change the engine for some
F#$% reson the bulb when, twice on me, that's another $400.
Good Luck
What About Bob
Timmins, Ontario
Home of Shania Twain
Anonymous
  • 2920 Answers
  • Posted on Jan 04, 2009
SOURCE: Blue dots all over screen and getting worse
dead pixels you need to have it looked at
Anonymous
  • 790 Answers
  • Posted on Jul 08, 2009
SOURCE: White dots are all over the screen of 50" DLP TV
Hi
if you use the local channel the raster is coming out? or try to use the DVD input video then testrun if the raster is there you have defective video driver and need to replace
Thanks!
Anonymous
  • 10 Answers
  • Posted on Jan 17, 2010
SOURCE: Numerous white spots on Smasung DLP TV
This is a known issue with many Samsung DLP sets. The complete solution is here:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Be sure to read the entire post before acting to avoid being charged for the service.
There are white dots on my Mitsubishi TV screen. They started on the left side and spread throughout
LCD's are bad, warranty won't fit just a few, only a lot, yours aren't enough for warranty, best get new tv, they are expensive to fix
Why are white dots multiplying on screen?
DLP chip needs replaced...about $200 for the chip and replace yourself. YouTube has videos on how to replace
My Mitsubishi TV has a small white dot on the screen
This could be something on the lens or mirrors. you can open one or both porthole covers on the left or right side of TV to determine if this is the cause. You can look at the mirrors & lens to determine if a bug or dust has gotten on either part. Then clean.
HOWEVER, the most likely cause is the DLP chip. this causes white & or black dots. May start out as one or two, then multiply.
See the following website for the proper DLP chip for your Mitsubishi model#:
http://www.shopjimmy.com/catalogsearch/result/index/?cat=24&q=dlp+chip
4helpful
2answers
Small white dots have started to appear on our screen, first, on, then a couple days later 2 more, and today we have 6 small white dots on our screen. What is happening to cause this condition?
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
8helpful
I have white and black spots on my 65in hd1080p what is it tv is on 2 years old
Hi, I have a mitsubishi 65" DLP model # 65733 that I bought in December 2007 brand new, about six months ago I started spoting white dots on my screen that started blinking and then became permanent, thinking is was dust I cleaned everything inside with compressed air without success.
The stars multiply daily to a point that it was intolerable to watch anything with all the white stars and a few black ones that showed up.
We called mitsubishi but got no where, I was out of warranty. (they still deny having a problem with their DLP's)
I had a service tech inspect the tv and was told it could run about $800 to $1000 to replace the light engine with refurbished parts with 90 day warranties.
Researching on line I came across a DLP chip that is compatible with several mitsubishi and samsung models, so I decided to chance it, and replace just the DMD chip before we trash the tv, it was unthinkable to pay $800 to repair a tv that we could buy now for under $900.
Thanks God the "gamble" paid out and the problem got solve with just $150 DLP chip in about 15 minutes of my time.
If you are not mechanically nor electronically inclined, I recommend you use a technician for the installation, but don't let anyone tell you you need to replace the whole light engine, it is a ripoff.
If your problem is just white or black dots on the screen that do not move.......this will solve your problem!!
P.S. Hope this will help you and for the record..... "I will never buy a mitsubishi product again".
My projector is showing multiple white dots, looks like lots of small stars all over the screen when projected to screens. is this mean I need to replace the lamp? TDP-XP1 model.
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
