KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
laureano Posted on Mar 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator light no work i change light bulb and door swicht
Jerry Radcliffe
Level 3:
Master:
  • Master 483 Answers
  • Posted on Mar 08, 2013
Jerry Radcliffe
Master
Level 3:
Master:
Answers
483
Questions
0
Helped
92583
Points
1325
Was old lamp hard to unscrew from socket? maybe over tightening lamp has mashed center tab in lamp socket down
Lights wont work on refrigerator side changed bulbs not the problem
The socket that holds the bulb may have a burnt wire or the door switch that operates the light may be bad.
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Replace door switch
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Before you change you door light switch. Lets check it out. First, if you have changed the light bulb, did you use a refrigeration light bulb. These bulbs sometimes are available in your local food market. If you used a household light bulb it eventually will fail. The household bulb is not designed for cold temperatures.
All appliances require specific light bulbs designed to the application such as, refrigerators, freezers, dishwashers, clothes washers and dryers. Of course they are more expensive $8.00-$10.00.
Ok, lets assume you have the correct appliance light bulb in your refrigerator. With the door open push on the door light switch. If the light comes on your door switch.
All door switches are basically the same they are plastic two contacts, except for one that is a 3 contact switch. The third contact controls the ice dispenser. This switch is on the left side of the freezer wall (Liner).
Ok, lets change a door light switch. Unplug your refrigerator. With a small flat head screw driver (or butter knife) wedge behind the plastic switch frame. Pop it out. Be careful, do not pull it out too far. You will see the two connectors. It may be difficult to remove the connector, so wedge them with a flat head screw driver (Or butter knife). Do not pull on the wires, just the metal connector.
Ok, with your particular model the contact switch is on the top of your unit. There are two screws holding the hinge cover plate. These screws are either Phillips head or hex head. Either 1/4" or 5/16" hex head. Remove the hinge top cover. You have one on each side. There is a connector. With a small screw driver, wedge into the connector to release it. The rest is yours.
Peter, Glen Burnie, Maryland, USA
My wine cooler door swicht is not working,light is on even with the door closed
The switch is bad. Two wire simple switch. Replace it. Un-plug before replacing.
Light will not work even with new bulbs. Fan
one of your micro swichts are bad.
Internal light not working.I have changed the bulb,but it appears there is no power to the light socket.
hi there this roblem is usually caused by either ...(a) blown bulb....(2) fauly door switch.....
remedy....test and if necessary relace bulb...remove and if caable reair door switch or relace the switch
regards Sir Galahad
2helpful
3answers
Light won't work even tho changed bulb whirlpool fridge
Have you checked the door switch, might be stuck in or defective.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
