Okay, Follow these steps to fix out this issue:
METHOD 1: Re-installing the application
Step 1 - Go to the application that you got the error with.
Step 2 - Open that application download page on the Play store.
Step 3 - Uninstall it or even uninstall all the update (If the error came when you were updating the application).
Step 4 - Now you clear the task manager and try installing it once again. If the play store error 920 doesn't come then you have solved the problem and now wasn't that easy. So it's always best to try this step before doing anything else.
METHOD 2: Switching off and turning the wifi (cellular data) on
Step 1 - To remove that load Just turn your wifi off and then turn your wifi on (the same goes with your cellular data).
Step 2 - Now after doing this go to your Play Store application and download the application that you were going to download. Now your Play Store Error 920 won't be bothering you anymore.
METHOD 3: Clearing the cache and data of Google Play Store
Step 1 - Go to settings of your device.
Step 2 - Now find "Applications" option under the settings menu. Here you can find "Google Play Store" option. Open it.
Step 3 - Now, at the bottom, you can find "Clear Cache" option. Tap on it and your all cache will be cleared.
METHOD 4: Removing and adding back your Google account
Step 1 - go to Settings of your Mobile.
Step 2- Now, find "Accounts" and then go to "Google Accounts".
Step 3 - In that section find the account you use for the play store or the account that you were using while the error came in. Once you tap on your specific account you'll find an option to remove the account. Tap on it.
Step 4 - Now you have successfully removed your account and after that re-add your account. After entering your email id and password and hence adding your account. Go back to the play store and find the application that you were downloading or updating when the error code 920 came in. Now re-install it or update it back again. This time you won't be faced with the play store error 920.
For any help visit us: Hbo Go Help
