Question about GE WHRE5260E Top Load Washer
I have a Kitchen aid dishwasher (KUPD01ILBS3). I found it leaking at the fill valve, replaced it and fixed that leak only to find it leaking at the base of the tub where the motor housing is. Should I replace the gasket or use silicone to reseal it. The gasket does not look damaged and the unit is not that old. P.S. it was in storage for a few months.
    Top Expert:
  • GE Master
  • 6,289 Answers
Replace gasket.
Posted on Sep 29, 2017
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Washing machine
Deatsy, my advice would to buy a new washer. These GE's transmissions are not fun to replace. Taking the age in consideration the job could be compounded by rusting or corroded parts. Get a Whirlpool or Kenmore direct drive and it should give you years of service at a reasonable price. Information on the price of the transmission can be found here: http://www.repairclinic.com/0080.asp Catriver, post back.
Posted on Jan 22, 2007
Anonymous
SOURCE: GE Dishwasher GSD4020Z07BB is leaking water and doesn't drain
yes...mine leaks at the door base as well
Posted on Jan 30, 2008
Anonymous
  • 1028 Answers
SOURCE: Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Posted on Jun 17, 2008
Anonymous
SOURCE: GE Front Load Washer
Had the same problem and did 2 things to fix. Remove the bottom panel on the washer(3 screws on bottom front). Just to the right of the center is a white plug that you can unscrew. Before you unscrew, get an 8x8 cake pan underneath to catch the water that comes out(bigger if there is water stuck in your washer). Unscrew cap and take out filter. My filter had pocket change, bandaids, tape, hairpins etc in it(kids do their own laundry and aren't vigilant about checking pockets). Screw filter back in and put panel back on.
Also, lint was drying on washer tub viewing glass where gasket hit it. Gasket wasn't making a good seal there and thats where water leaked out. Clean the dried lint off. No more leaking for me.
Posted on Aug 10, 2008
Anonymous
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
My Hot Point Dishwasher is leaking water. It was
Hi
Check for any kind of leaks around lower spray arm or soap door. Replace the arm if any cracks are found. Also make sure that door latches firmly, and the gasket is not cut.
The leak can also happen due to a broken fill valve. To check, take off the access panel from the front of the dishwasher so you can reach the fill valve attached to the metal bracket. Use a multimeter to check the continuity across the two black terminals at the top of the fill valve. If it reads 120 V, replace the fill valve. Make sure the thin filter screen between the bracket and fill valve is not blocked by debris.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I have a kitchen aid refrigerator KSRG22FTSS01 that the icemaker continues to freeze up in the delivery tube, any suggestions why
This is the fill Tube to the Ice maker tray. It is freezing because the water valve is leaking a little even when it should be closed. This leak is now freezing your fill tube. If you defrost the tube it will work untill it freezes again. The only solution is to replace the water valve. The valve part number for your machine is 4389178
Jan 14, 2010 | Refrigerators
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
KitchenAid KDS-16 dishwasher, leaking from fill air gap
Peace,
If you want to try it okay .
but i think there are more variables and
you need hands on service tech with experiance!
Sep 06, 2008 | Dishwashers
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
KitchenAid Dishwasher fill up with water after use
Is the water clean water or dirty water? This may sound like an ignorant question, but it can make a difference. If the water is clean water, it sounds like you could have a bad fill valve. If the dishwasher is filling with water when it is not running, chances are the fill valve is leaking. The valve is closed when the float switch senses the tub filling to a certain level. The valve is also closed when not energized by the control board during drain, drying and off cycles. However, if the valve diaphragm is not seating properly when closed, it will continue to leak by. That's probably why you don't notice it while is running and it has a chance to fill during the night when not in use. Here's what to look for: With the dishwasher off, take a towel and dry the tub as much as possible. Now, locate the fill port where the water comes in (usually on the left hand side of the tub). Watch this fill port closely for several minutes to see if water is running in. It could be as minute as a trickle or drip. If any water is coming in at all, the fill valve should be replaced. Now, another problem that can occur is when you notice dirty water staying in the tub or overflowing. This is usually caused by a bad check valve in the drain pump that's allowing water to leak back from the sink into the tub. Or, you do not have a high loop in the drain line. Here's what to look for: Check to make sure the drain line has a high loop as it leaves the dishwasher and before it gets to the drain pipe at the sink. That is, make sure the drain hose is looped above the trap in the sink and not laying under the sink somewhere. You can also try filling the sink with water and open the dishwasher door. Drain the sink to see if anything is getting fed back into dishwasher. If you see water starting to fill in the tub, chances are you could have a bad check valve. Some dishwashers have a check valve in the drain pump, while other models have the check valve located in the drain hose itself. Some don't have one at all. That's why the positioning of the drain hose can be important. Good luck to you and I hope this may help. If you determine a cause, post back with comments if you need advice on how to replace anything.
Sep 22, 2007 | KitchenAid 24 in. KUDS25 Built-in...
GE WHRE5260E Top Load Washer Logo
64 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
