This problem started out with tv shutting down after operation for a time then if left to sit for a while would turn back on.
Now it wont turn on at all red standby light comes on an when switched on turns green for a second then back to red.
Any help with this problem would be greatly appreciated with the economy like it is money is tight and a new tv now is not gonna be possible. Thanks Phil Z in Baltimore
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance
I have the same problem. Did you get any solution?
Thanks,
Ram
I HAVE THE SAME PROBLEM. I HAD GEEK SQUAD COME OUT. THEY SAID IMAY HAVE TO REPLACE " BOARD". THE BOARD IS NO LONGER AVAILABLE. IT WAS JUST A GUESS THOUGH. ANY OTHER SOLUTIONS?
